Installing the HTC Thunderbolt Rear Frame
  1. Installing the HTC Thunderbolt Rear Frame, Rear Panel: step 1, image 1 of 1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. Installing the HTC Thunderbolt Rear Frame: step 2, image 1 of 1
    • Lift and remove the rear panel.
  3. Installing the HTC Thunderbolt Rear Frame, Battery: step 3, image 1 of 2 Installing the HTC Thunderbolt Rear Frame, Battery: step 3, image 2 of 2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. Installing the HTC Thunderbolt Rear Frame, MicroSD Card: step 4, image 1 of 2 Installing the HTC Thunderbolt Rear Frame, MicroSD Card: step 4, image 2 of 2
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
  5. Installing the HTC Thunderbolt Rear Frame: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
  6. Installing the HTC Thunderbolt Rear Frame, Rear Frame: step 6, image 1 of 1
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
  7. Installing the HTC Thunderbolt Rear Frame: step 7, image 1 of 2 Installing the HTC Thunderbolt Rear Frame: step 7, image 2 of 2
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
  8. Installing the HTC Thunderbolt Rear Frame: step 8, image 1 of 1
    • Remove the two Phillips screws where the plastic cover was.
  9. Installing the HTC Thunderbolt Rear Frame: step 9, image 1 of 2 Installing the HTC Thunderbolt Rear Frame: step 9, image 2 of 2
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
  10. Installing the HTC Thunderbolt Rear Frame: step 10, image 1 of 3 Installing the HTC Thunderbolt Rear Frame: step 10, image 2 of 3 Installing the HTC Thunderbolt Rear Frame: step 10, image 3 of 3
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
Brandon Younger
212 Reputation
8 Guides authored
Cal Poly, Team 19-45, Regan Winter 2013 Member of Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Members
24 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 484
