Installing HTC Thunderbolt Camera
  1. Installing HTC Thunderbolt Camera, Rear Panel: step 1, image 1 of 1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. Installing HTC Thunderbolt Camera: step 2, image 1 of 1
    • Lift and remove the rear panel.
  3. Installing HTC Thunderbolt Camera, Battery: step 3, image 1 of 2 Installing HTC Thunderbolt Camera, Battery: step 3, image 2 of 2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. Installing HTC Thunderbolt Camera, Rear Frame: step 4, image 1 of 1
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
  5. Installing HTC Thunderbolt Camera: step 5, image 1 of 2 Installing HTC Thunderbolt Camera: step 5, image 2 of 2
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
  6. Installing HTC Thunderbolt Camera: step 6, image 1 of 1
    • Remove the two Phillips screws where the plastic cover was.
  7. Installing HTC Thunderbolt Camera: step 7, image 1 of 2 Installing HTC Thunderbolt Camera: step 7, image 2 of 2
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
  8. Installing HTC Thunderbolt Camera: step 8, image 1 of 3 Installing HTC Thunderbolt Camera: step 8, image 2 of 3 Installing HTC Thunderbolt Camera: step 8, image 3 of 3
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
  9. Installing HTC Thunderbolt Camera, Rear Inner Frame: step 9, image 1 of 1
    • Remove the two Phillips screws securing rear inner frame to device.
  10. Installing HTC Thunderbolt Camera: step 10, image 1 of 1
    • Insert the plastic opening tool between the rear inner frame and the motherboard and slowly work your way around the device.
  11. Installing HTC Thunderbolt Camera: step 11, image 1 of 2 Installing HTC Thunderbolt Camera: step 11, image 2 of 2
    • Remove the rear inner frame from the rest of the device.
  12. Installing HTC Thunderbolt Camera, LCD/Screen: step 12, image 1 of 2 Installing HTC Thunderbolt Camera, LCD/Screen: step 12, image 2 of 2
    Tool used on this step:
    Buy
    • Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable.
    • Be careful opening these tabs as they are very easy to break.
    • Use a pair of tweezers to pull the capacitive button cable out of its socket.
  13. Installing HTC Thunderbolt Camera: step 13, image 1 of 2 Installing HTC Thunderbolt Camera: step 13, image 2 of 2
    • Lifting from the side where the ribbon was disconnected, flip over the motherboard.
    • Remove the black tape covering the tabs connecting the motherboard and LCD.
  14. Installing HTC Thunderbolt Camera: step 14, image 1 of 1
    • Using the plastic opening tool pop up the two tabs connecting the LCD and motherboard.
  15. Installing HTC Thunderbolt Camera: step 15, image 1 of 2 Installing HTC Thunderbolt Camera: step 15, image 2 of 2
    • Once the tabs have been popped up, slowly pull the two pieces away from each other.
    • If there is resistance pulling apart the phone then a ribbon or tab has not been disconnected properly/completely.
  16. Installing HTC Thunderbolt Camera, Motherboard: step 16, image 1 of 1
    • The motherboard should now be completely disconnected
  17. Installing HTC Thunderbolt Camera, Camera: step 17, image 1 of 2 Installing HTC Thunderbolt Camera, Camera: step 17, image 2 of 2
    • Use a finger nail to get in between the tape and the phone, then pull the tape off gently.
  18. Installing HTC Thunderbolt Camera: step 18, image 1 of 1
    • Pop up the tab connecting the camera to the motherboard.
  19. Installing HTC Thunderbolt Camera: step 19, image 1 of 1
    • Flip over motherboard and using tweezers gently grab the camera, then pull back and up.
Vanessa
60 Reputation
4 Guides authored
Cal Poly, Team 19-45, Regan Winter 2013 Member of Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Members
24 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 983
