HTC SMT 6175 Keyboard Replacement
  1. HTC SMT 6175 Keyboard Replacement, Back Case: step 1, image 1 of 1
    • First, flip the phone over so that the back is facing upwards.
  2. HTC SMT 6175 Keyboard Replacement: step 2, image 1 of 2 HTC SMT 6175 Keyboard Replacement: step 2, image 2 of 2
    • Using both thumbs, push the back side of the phone's exterior up and remove the front face of the phone.
  3. HTC SMT 6175 Keyboard Replacement, Battery: step 3, image 1 of 2 HTC SMT 6175 Keyboard Replacement, Battery: step 3, image 2 of 2
    • Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
  4. HTC SMT 6175 Keyboard Replacement, Keyboard: step 4, image 1 of 2 HTC SMT 6175 Keyboard Replacement, Keyboard: step 4, image 2 of 2
    • To remove the back casing inside the phone, unscrew the 6 screws that are around the perimeter of the phone.
  5. HTC SMT 6175 Keyboard Replacement: step 5, image 1 of 2 HTC SMT 6175 Keyboard Replacement: step 5, image 2 of 2
    • Carefully pull off back casing.
    • Warning: This can be difficult, but just start pulling the back out from the front shell. As it starts to lift up, continue moving around the phone until the whole back becomes free.
  6. HTC SMT 6175 Keyboard Replacement: step 6, image 1 of 2 HTC SMT 6175 Keyboard Replacement: step 6, image 2 of 2
    • Next unscrew the top screw.
    • Warning: Be CAREFUL because the LCD screen is still attached to the front side of the motherboard by a flexible ribbon cable.
  7. HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: step 7, image 1 of 3 HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: step 7, image 2 of 3 HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: step 7, image 3 of 3
    • Pull the plastic keyboard away from the front case.
  8. HTC SMT 6175 Keyboard Replacement, Navigation Keys: step 8, image 1 of 3 HTC SMT 6175 Keyboard Replacement, Navigation Keys: step 8, image 2 of 3 HTC SMT 6175 Keyboard Replacement, Navigation Keys: step 8, image 3 of 3
    • To remove the navigation keys on the front of the phone, unscrew the four screws circled using a Philips screwdriver.
    • Remove the navigation keys from the front of the phone. They should pop out as a unit.
Luke Plewa
116 Reputation
4 Guides authored
Cal Poly, Team 25-29, Garner Spring 2011 Member of Cal Poly, Team 25-29, Garner Spring 2011
CPSU-GARNER-S11S25G29
3 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 1,681
