This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
HTC One A9s Display Replacement
      • Switch off the device.
      Ask FixBot
      • Heat the top edge of the display with a heat gun or hair dryer.
      • Insert a Jimmy between the display and the housing at the top edge.
      • Separate the display from top to bottom.
      • Do not pull the display off completely while the ribbon cables are still connected.
      Ask FixBot
      • Carefully pry up the display.
      • Use a screwdriver to disconnect the cover plate over the display connectors.
      Ask FixBot
      • Disconnect the display cables.
      • Connect the new display and test it before you install it completely.
      Ask FixBot
      • If the new display functions successfully, replace the cover plate and screw it on.
      Ask FixBot
Before installing the new display, remove old adhesive residue from the adhesive surfaces. Use new display adhesive or a suitable gasket if you want to maintain water and dust protection as much as possible.
After reassembly, check that the new display is working correctly.
Special thanks to these translators:
de en
100%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
Marten
806 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 51
All Time: 328
