HTC Maple 100 Motherboard Replacement
  1. HTC Maple 100 Motherboard Replacement, Battery: step 1, image 1 of 1
    • First remove the back cover of your phone to expose the battery.
  2. HTC Maple 100 Motherboard Replacement: step 2, image 1 of 1
    • Turn the phone over.
    • Push forward on the battery with your thumb.
  3. HTC Maple 100 Motherboard Replacement: step 3, image 1 of 2 HTC Maple 100 Motherboard Replacement: step 3, image 2 of 2
    • Take the battery out by lifting it upwards.
    • When reassembling, make sure that the battery contacts match up.
  4. HTC Maple 100 Motherboard Replacement, Back Panel: step 4, image 1 of 2 HTC Maple 100 Motherboard Replacement, Back Panel: step 4, image 2 of 2
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
  5. HTC Maple 100 Motherboard Replacement: step 5, image 1 of 1
    • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
  6. HTC Maple 100 Motherboard Replacement: step 6, image 1 of 3 HTC Maple 100 Motherboard Replacement: step 6, image 2 of 3 HTC Maple 100 Motherboard Replacement: step 6, image 3 of 3
    • Insert the plastic opening tool along the seams at different points to it pry the clips off.
    • This may require a bit of force. The USB port cover may fall off in this step.
  7. HTC Maple 100 Motherboard Replacement, Motherboard: step 7, image 1 of 2 HTC Maple 100 Motherboard Replacement, Motherboard: step 7, image 2 of 2
    • Remove the one 3.3mm #00 screw.
  8. HTC Maple 100 Motherboard Replacement: step 8, image 1 of 2 HTC Maple 100 Motherboard Replacement: step 8, image 2 of 2
    • Use your finger or the plastic opening tool to unclip the board.
    • Be aware of the ribbon cable connected to the motherboard inside the phone.
  9. HTC Maple 100 Motherboard Replacement: step 9, image 1 of 2 HTC Maple 100 Motherboard Replacement: step 9, image 2 of 2
    • Peel off the yellow piece of tape from the phone.
  10. HTC Maple 100 Motherboard Replacement: step 10, image 1 of 3 HTC Maple 100 Motherboard Replacement: step 10, image 2 of 3 HTC Maple 100 Motherboard Replacement: step 10, image 3 of 3
    • First flip up the retaining flap with your fingernail or a plastic opening tool.
    • Pull on the ribbon cable gently with your fingers
  11. HTC Maple 100 Motherboard Replacement: step 11, image 1 of 2 HTC Maple 100 Motherboard Replacement: step 11, image 2 of 2
    • Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable.
  12. HTC Maple 100 Motherboard Replacement: step 12, image 1 of 2 HTC Maple 100 Motherboard Replacement: step 12, image 2 of 2
    • Gently pull on the ribbon cable to separate the motherboard.
Andrew Van Meter
24 Reputation
3 Guides authored
Cal Poly, Team 20-29, Maness Fall 2011 Member of Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Members
18 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,087
