Installing HTC Inspire 4G Display Assembly
  1. Installing HTC Inspire 4G Display Assembly, Display Assembly: step 1, image 1 of 3 Installing HTC Inspire 4G Display Assembly, Display Assembly: step 1, image 2 of 3 Installing HTC Inspire 4G Display Assembly, Display Assembly: step 1, image 3 of 3
    • Remove battery cover using a plastic opening tool or finger nail.
    • Slide opening tool to release clasps and remove battery cover.
  2. Installing HTC Inspire 4G Display Assembly: step 2, image 1 of 3 Installing HTC Inspire 4G Display Assembly: step 2, image 2 of 3 Installing HTC Inspire 4G Display Assembly: step 2, image 3 of 3
    • With the cover removed, the battery will fall freely with a gentle shake.
  3. Installing HTC Inspire 4G Display Assembly: step 3, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 3, image 2 of 2
    • Remove SIM card cover by simultaneously squeezing cover and pulling it off of the phone.
  4. Installing HTC Inspire 4G Display Assembly: step 4, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 4, image 2 of 2
    • Slide SIM card out.
  5. Installing HTC Inspire 4G Display Assembly: step 5, image 1 of 3 Installing HTC Inspire 4G Display Assembly: step 5, image 2 of 3 Installing HTC Inspire 4G Display Assembly: step 5, image 3 of 3
    • Remove Micro SD card by pushing it in to the phone. Spring-loaded clasp will release the card.
  6. Installing HTC Inspire 4G Display Assembly: step 6, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 6, image 2 of 2
    • Use a curved metal spudger to remove GPS cover.
    • Probe underside of GPS cover until you can force a small opening between GPS cover and back cover of phone.
  7. Installing HTC Inspire 4G Display Assembly: step 7, image 1 of 3 Installing HTC Inspire 4G Display Assembly: step 7, image 2 of 3 Installing HTC Inspire 4G Display Assembly: step 7, image 3 of 3
    • Insert plastic opening tool into gap between GPS cover and back cover of phone. Slide tool along GPS cover and pry the piece off.
  8. Installing HTC Inspire 4G Display Assembly: step 8, image 1 of 3 Installing HTC Inspire 4G Display Assembly: step 8, image 2 of 3 Installing HTC Inspire 4G Display Assembly: step 8, image 3 of 3
    • Remove "VOID" sticker from screw.
    • If your phone has a warranty, removing "VOID" sticker will void your warranty.
  9. Installing HTC Inspire 4G Display Assembly: step 9, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 9, image 2 of 2
    • Remove four 2.2mm T5 torx screws.
    • Remove one 4.5mm T5 torx screw.
  10. Installing HTC Inspire 4G Display Assembly: step 10, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 10, image 2 of 2
    • Remove display cable shield.
    • Insert probing tool into screw hole and pull shield.
    • Be careful! This piece is made of thin, springy metal and will fly across the room if you remove it too forcefully.
  11. Installing HTC Inspire 4G Display Assembly: step 11, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 11, image 2 of 2
    • Peel off manufacturer's information sticker.
  12. Installing HTC Inspire 4G Display Assembly: step 12, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 12, image 2 of 2
    • Lift volume button assembly out of the back case.
    • Work slowly! Initially, you must lever the assembly from the ribbon cable attaching it to the upper logic board. The cable is delicate.
  13. Installing HTC Inspire 4G Display Assembly: step 13, image 1 of 3 Installing HTC Inspire 4G Display Assembly: step 13, image 2 of 3 Installing HTC Inspire 4G Display Assembly: step 13, image 3 of 3
    • Push up on the back cover, wiggling cover back and forth, until it slides off.
  14. Installing HTC Inspire 4G Display Assembly: step 14, image 1 of 3 Installing HTC Inspire 4G Display Assembly: step 14, image 2 of 3 Installing HTC Inspire 4G Display Assembly: step 14, image 3 of 3
    • Remove "VOID" sticker.
    • If your phone has a warranty, removing the "VOID" sticker will void your warranty.
    • Remove three 2.4mm T5 torx screws.
  15. Installing HTC Inspire 4G Display Assembly: step 15, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 15, image 2 of 2
    • Apply pressure to the bottom of the plastic logic board shield and it will pop right off.
  16. Installing HTC Inspire 4G Display Assembly: step 16, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 16, image 2 of 2
    • Remove rubber spacer.
  17. Installing HTC Inspire 4G Display Assembly: step 17, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 17, image 2 of 2
    • Peel off Mylar tape.
  18. Installing HTC Inspire 4G Display Assembly: step 18, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 18, image 2 of 2
    • Peel off electrical tape.
  19. Installing HTC Inspire 4G Display Assembly: step 19, image 1 of 3 Installing HTC Inspire 4G Display Assembly: step 19, image 2 of 3 Installing HTC Inspire 4G Display Assembly: step 19, image 3 of 3
    • Pry display assembly connector off of lower logic board.
  20. Installing HTC Inspire 4G Display Assembly: step 20, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 20, image 2 of 2
    • Remove metal bracket.
  21. Installing HTC Inspire 4G Display Assembly: step 21, image 1 of 3 Installing HTC Inspire 4G Display Assembly: step 21, image 2 of 3 Installing HTC Inspire 4G Display Assembly: step 21, image 3 of 3
    • Remove speaker.
    • During reassembly, be careful with the spring connectors on the reverse side of the speaker unit. They are bent easily.
    • This rubber spacer is held on by a weak adhesive. Be careful with this during reassembly, as it may catch and crumple as you put the back panel back the phone.
  22. Installing HTC Inspire 4G Display Assembly: step 22, image 1 of 1
    • Remove one 1.5mm #00 Phillips screw.
    • Remove two 2.5mm T5 torx screws.
  23. Installing HTC Inspire 4G Display Assembly: step 23, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 23, image 2 of 2
    • Remove earpiece speaker connector.
  24. Installing HTC Inspire 4G Display Assembly: step 24, image 1 of 3 Installing HTC Inspire 4G Display Assembly: step 24, image 2 of 3 Installing HTC Inspire 4G Display Assembly: step 24, image 3 of 3
    • Pry off Bluetooth coaxial cable connector.
    • Unwind Bluetooth coaxial cable from plastic camera shield.
  25. Installing HTC Inspire 4G Display Assembly: step 25, image 1 of 3 Installing HTC Inspire 4G Display Assembly: step 25, image 2 of 3 Installing HTC Inspire 4G Display Assembly: step 25, image 3 of 3
    • Pry off plastic camera shield.
  26. Installing HTC Inspire 4G Display Assembly: step 26, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 26, image 2 of 2
    • Heat black Mylar shield for easier removal.
    • As you can see, we attempted to peel off the Mylar shield before heating it. It required more force than we were comfortable with, so we turned up the heat!
    • Peel off Mylar shield.
  27. Installing HTC Inspire 4G Display Assembly: step 27, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 27, image 2 of 2
    • Gently separate upper logic board from mid chassis. The upper logic board is held to the mid chassis by copious amounts of strong adhesive.
  28. Installing HTC Inspire 4G Display Assembly: step 28, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 28, image 2 of 2
    • Gently separate lower logic board from mid chassis. The lower logic board is held to the mid chassis by copious amounts of strong adhesive.
  29. Installing HTC Inspire 4G Display Assembly: step 29, image 1 of 1
    • Once the adhesive-laden logic boards are separated from the mid chassis, the entire assembly easily comes off.
    • Be careful when handing the logic board assembly. We could have separated out each part, but decided it was a waste of time. The cost of cutting this corner is extra care when handling the logic board assembly.
  30. Installing HTC Inspire 4G Display Assembly: step 30, image 1 of 2 Installing HTC Inspire 4G Display Assembly: step 30, image 2 of 2
    • Blast the front panel with heat and pry between the display assembly and front panel bezel, working one or several guitar picks around the display assembly.
    • Once the display assembly is loosened from the front panel, it will fall away.
    • The front glass came off easily, but the digitizer was much more difficult to remove. The adhesive holding together the display assembly is much weaker than the adhesive holding the display assembly to the front panel.
    • While creating this guide, I utterly destroyed the front panel bezel and digitizer. Replacing the display assembly was a breeze--but removing the digitizer required nearly a dozen reheats of the front panel. To replace the bezel, you will need a new "mid chassis" (that's the front panel piece the digitizer is so powerfully glued to).
Jeff Snyder
8,817 Reputation
4 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,410 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 5,360
