Introduction
This guide is for the replacement of the battery for the HTC Evo 4g smart phone. the battery may need to be replaced if your phone looses power suddenly without warning, or if your phone’s battery life has reduced substantially.
Warnings
- Make sure that your phone is turned off completely to avoid any damage to you or your device.
- Damaged batteries are dangerous, if your phone’s battery has and visual damage, swelling, or obvious discoloration do not attempt to remove the battery yourself.
- Removed batteries should be disposed of properly, batteries are considered hazardous waste and should not be thrown away. research the area you live in and dispose of any batteries via local solid waste disposal.
- Do not under any circumstances purposefully damage, puncture, or heat batteries. batteries are hazardous when damaged and under the right circumstance become explosive under the right circumstances.
The first step is to remove the back case of the phone preferably with a plastic opening tool.
The next step is to remove the battery from the phone by carefully lifting it out with your fingers.
