HTC Desire 610 Vibration Motor Replacement
  1. HTC Desire 610 Vibration Motor Replacement, Black Plastic Circuit Cover: step 1, image 1 of 3 HTC Desire 610 Vibration Motor Replacement, Black Plastic Circuit Cover: step 1, image 2 of 3 HTC Desire 610 Vibration Motor Replacement, Black Plastic Circuit Cover: step 1, image 3 of 3
    • Using a plastic opening tool, take off the back cover of the phone.
  2. HTC Desire 610 Vibration Motor Replacement: step 2, image 1 of 1
    • Remove the four black 4mm torx screws using the Torx T5 bit.
  3. HTC Desire 610 Vibration Motor Replacement: step 3, image 1 of 1
    • Remove the four silver 5mm torx head screws using the Torx T5 screwdriver.
  4. HTC Desire 610 Vibration Motor Replacement: step 4, image 1 of 1
    • Remove the two 2.5mm phillips head screws using the Phillips 000 screwdriver.
  5. HTC Desire 610 Vibration Motor Replacement: step 5, image 1 of 1
    • Remove the black plastic circuit cover using a plastic opening tool.
  6. HTC Desire 610 Vibration Motor Replacement, Vibration Motor: step 6, image 1 of 2 HTC Desire 610 Vibration Motor Replacement, Vibration Motor: step 6, image 2 of 2
    • Pull the wire harness from the circuit board that is connected to the vibration motor using a pair of precision tweezers.
    • Be careful! Damaging this port could prevent a new vibration motor from functioning.
  7. HTC Desire 610 Vibration Motor Replacement: step 7, image 1 of 2 HTC Desire 610 Vibration Motor Replacement: step 7, image 2 of 2
    • Pry the vibration motor from it's housing using precision tweezers.
    • The vibration motor is held in place with adhesive, so you may need to pry a little harder to remove it.
Kaycee Hammond
273 Reputation
2 Guides authored
IUPUI, Team S1-G1, Wilson Spring 2017 Member of IUPUI, Team S1-G1, Wilson Spring 2017
IUPUI-WILSON-S17S1G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 415
