HTC Desire 610 Daughterboard Replacement
  1. HTC Desire 610 Daughterboard Replacement, Daughterboard: step 1, image 1 of 1
    • Open the SD card slot.
  2. HTC Desire 610 Daughterboard Replacement: step 2, image 1 of 3 HTC Desire 610 Daughterboard Replacement: step 2, image 2 of 3 HTC Desire 610 Daughterboard Replacement: step 2, image 3 of 3
    • Using plastic opening tool, take off the back cover of the phone.
  3. HTC Desire 610 Daughterboard Replacement: step 3, image 1 of 1
    • Using Phillips #000 Screwdriver, remove the two 2.5mm phillips head screws.
  4. HTC Desire 610 Daughterboard Replacement: step 4, image 1 of 1
    • Using Torx T5 Screwdriver, remove the four 5mm silver torx head screws.
  5. HTC Desire 610 Daughterboard Replacement: step 5, image 1 of 1
    • Using Torx T5 Screwdriver, remove the four 4mm black torx screws
  6. HTC Desire 610 Daughterboard Replacement: step 6, image 1 of 2 HTC Desire 610 Daughterboard Replacement: step 6, image 2 of 2
    • Using plastic opening tool, remove the black plastic circuit cover.
  7. HTC Desire 610 Daughterboard Replacement: step 7, image 1 of 1
    • Using Torx T5 Screwdriver, remove the 4mm black torx screw.
  8. HTC Desire 610 Daughterboard Replacement: step 8, image 1 of 2 HTC Desire 610 Daughterboard Replacement: step 8, image 2 of 2
    • Using Tweezers, disconnect antenna wire.
  9. HTC Desire 610 Daughterboard Replacement: step 9, image 1 of 3 HTC Desire 610 Daughterboard Replacement: step 9, image 2 of 3 HTC Desire 610 Daughterboard Replacement: step 9, image 3 of 3
    • Using Tweezers, remove loud speaker that is being held by small adhesive.
    • When putting loud speaker back on, the prongs sticking up should be on the side closer to the top of the phone.
  10. HTC Desire 610 Daughterboard Replacement: step 10, image 1 of 2 HTC Desire 610 Daughterboard Replacement: step 10, image 2 of 2
    • Using Tweezers, peel back gray adhesive.
  11. HTC Desire 610 Daughterboard Replacement: step 11, image 1 of 2 HTC Desire 610 Daughterboard Replacement: step 11, image 2 of 2
    • Using Tweezers, flip the white strip upward so it sits 90°.
  12. HTC Desire 610 Daughterboard Replacement: step 12, image 1 of 3 HTC Desire 610 Daughterboard Replacement: step 12, image 2 of 3 HTC Desire 610 Daughterboard Replacement: step 12, image 3 of 3
    • Using plastic opening tool, pry up green plate and pull outward.
    • Daughterboard is off. Get new daughterboard and reverse steps.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,621
