Shop the Holiday Gift Guide
HTC Amaze Back Panel Disassembly
View statistics:
Past 24 Hours:
Past 7 Days:
2
Past 30 Days:
3
All Time:
211
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite Only
This guide will show how to remove the back panel of the HTC Amaze, which will then make it easier to access other components of the device.
Tools
    1. HTC Amaze Back Panel Disassembly, Battery: step 1, image 1 of 2 HTC Amaze Back Panel Disassembly, Battery: step 1, image 2 of 2
      • Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
      Ask FixBot
    2. HTC Amaze Back Panel Disassembly: step 2, image 1 of 1
      • Once you locate the battery, look for a notch below it.
      • Gently insert your fingernails into the notch.
      • Lift the battery out of its recess.
      Ask FixBot
    1. HTC Amaze Back Panel Disassembly, HTC Amaze Back Panel Disassembly: step 3, image 1 of 3 HTC Amaze Back Panel Disassembly, HTC Amaze Back Panel Disassembly: step 3, image 2 of 3 HTC Amaze Back Panel Disassembly, HTC Amaze Back Panel Disassembly: step 3, image 3 of 3
      • Use the Torx T5 screwdriver to remove the 7 Torx Screws (3mm) attached to the back housing of the device.
      • One of the Screws may have a tape attached to it that says void. Removing this screw will void the devices warranty.
      Ask FixBot
    2. HTC Amaze Back Panel Disassembly: step 4, image 1 of 3 HTC Amaze Back Panel Disassembly: step 4, image 2 of 3 HTC Amaze Back Panel Disassembly: step 4, image 3 of 3
      • Proceed to remove the back housing by using the spudger to gently unclip each clip holding the back housing in place and then lift the outer edges of the back housing
      • If you're having trouble opening the back try using the spudger to gently pry all around the panel before you attempt to remove it.
      Ask FixBot
    3. HTC Amaze Back Panel Disassembly: step 5, image 1 of 2 HTC Amaze Back Panel Disassembly: step 5, image 2 of 2
      • Now simply remove the back panel by gently pulling. This will make it easier to access the devices internal components.
      Ask FixBot
Author
with
Jonah DIngle
286 Reputation
2 Guides authored
USF Tampa, Team 16-3, Eyestone Fall 2016 Member of USF Tampa, Team 16-3, Eyestone Fall 2016
USFT-EYESTONE-F16S16G3
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 211
