Game Boy Advance On/Off Switch Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Game Boy Advance On/Off Switch Replacement, Remove the battery cover: step 1, image 1 of 3 Game Boy Advance On/Off Switch Replacement, Remove the battery cover: step 1, image 2 of 3 Game Boy Advance On/Off Switch Replacement, Remove the battery cover: step 1, image 3 of 3
    • Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
    • During reassembly, insert the tabs on the bottom edge of the cover into their cutouts and press the cover into place.
  2. Game Boy Advance On/Off Switch Replacement, Remove the batteries: step 2, image 1 of 3 Game Boy Advance On/Off Switch Replacement, Remove the batteries: step 2, image 2 of 3 Game Boy Advance On/Off Switch Replacement, Remove the batteries: step 2, image 3 of 3
    • Remove the two AA batteries.
    • If the metal terminals are corroded, follow this guide to clean them.
    • When installing batteries, use the diagram in the battery well to properly orient them.
  3. Game Boy Advance On/Off Switch Replacement, Remove the back shell screws: step 3, image 1 of 2 Game Boy Advance On/Off Switch Replacement, Remove the back shell screws: step 3, image 2 of 2
    • Remove the seven screws securing the back shell:
    • Six 9.4 mm‑long tri‑point Y0 screws
    • One 8.5 mm‑long JIS 1 screw
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping screws. Push down firmly on the driver and twist slowly.
  4. Game Boy Advance On/Off Switch Replacement, Remove the back shell: step 4, image 1 of 2 Game Boy Advance On/Off Switch Replacement, Remove the back shell: step 4, image 2 of 2
    • Lift the back shell straight up and remove it.
    • During reassembly, squeeze the shell firmly around the edges and ensure the shoulder buttons and bumpers are properly seated with no large gaps. Gently test the buttons to make sure everything feels correct.
  5. Game Boy Advance On/Off Switch Replacement, Remove Triggers: step 5, image 1 of 2 Game Boy Advance On/Off Switch Replacement, Remove Triggers: step 5, image 2 of 2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  6. Game Boy Advance On/Off Switch Replacement, Remove the On/Off Switch: step 6, image 1 of 1
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
6 other people completed this guide.
Adam
907 Reputation
6 Guides authored
Cal Poly, Team 16-29, Maness Winter 2010 Member of Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Members
81 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 51
All Time: 22,345
