HP w2216h Control Buttons Replacement
Views: 1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
89
All Time:
1,031
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Are you unable to adjust the sound on you HP w2216h monitor? You may need to replace your control buttons. These buttons are responsible for sound adjustment, calibration, input selection, and more.
Tools
    1. HP w2216h Control Buttons Replacement, Control Buttons: step 1, image 1 of 1
      • Make sure you are grounded, the power supply is not connected, and you are wearing safety goggles.
      • Remove the four 12 mm Phillips #000 screws on the back panel.
      Ask FixBot
    2. HP w2216h Control Buttons Replacement: step 2, image 1 of 2 HP w2216h Control Buttons Replacement: step 2, image 2 of 2
      • Remove the two 12 mm Phillips #000 screws above stand mounting bracket.
      • Using a Phillips #1 with the 150 mm flexible extension remove 1 Phillips #1 screw under the stand mounting bracket.
      • Stand will easily pull off.
      Ask FixBot
    3. HP w2216h Control Buttons Replacement: step 3, image 1 of 3 HP w2216h Control Buttons Replacement: step 3, image 2 of 3 HP w2216h Control Buttons Replacement: step 3, image 3 of 3
      • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
      • Turn monitor so that the screen is facing you.
      • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
      • The best places to pry are in the lower left and lower right corners of the black bezel.
      Ask FixBot
    4. HP w2216h Control Buttons Replacement: step 4, image 1 of 1
      • Lift the screen assembly from the plastic housing from the corners.
      Ask FixBot
    5. HP w2216h Control Buttons Replacement: step 5, image 1 of 1
      • Remove the plastic buttons from the contacts
      Ask FixBot
    6. HP w2216h Control Buttons Replacement: step 6, image 1 of 2 HP w2216h Control Buttons Replacement: step 6, image 2 of 2
      • Remove the wire connecting the contacts to the screen assembly.
      Ask FixBot
Patrick Aucoin
221 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 89
All Time: 1,031
