HP iPAQ h4155 Back Case Replacement
  1. HP iPAQ h4155 Back Case Replacement, Battery: step 1, image 1 of 1
    • While sliding the silver release tab up, simultaneously lift the cover up from the left side.
  2. HP iPAQ h4155 Back Case Replacement: step 2, image 1 of 1
    • Push the tab left to right to remove the cover.
  3. HP iPAQ h4155 Back Case Replacement: step 3, image 1 of 1
    • Now, lift the battery up and away from the device to remove it.
  4. HP iPAQ h4155 Back Case Replacement, Back Case: step 4, image 1 of 1
    • Remove the four silver screws using the T5 Torx Screwdriver (T5 x .25 in).
  5. HP iPAQ h4155 Back Case Replacement: step 5, image 1 of 1
    • Remove the single black screw (T5 x .125 in) beneath the HP sticker.
  6. HP iPAQ h4155 Back Case Replacement: step 6, image 1 of 2 HP iPAQ h4155 Back Case Replacement: step 6, image 2 of 2
    • Next, use your plastic removal tool to separate the gray back from the black center piece.
    • For better results, start the separation at the corner piece.
  7. HP iPAQ h4155 Back Case Replacement: step 7, image 1 of 1
    • Remove the back case.
John Pagliero
942 Reputation
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 922
