Introduction
Before replacing your hard drive make sure you have backed up all of your files and have an OS install disk on hand. Now you're ready to replace your hard drive!
Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
Locate four 3mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
Slide the hard drive out of the enclosure to complete the removal process.
