HP ZBook 15 Wi-Fi Card Replacement
  1. HP ZBook 15 Wi-Fi Card Replacement, Battery: step 1, image 1 of 2 HP ZBook 15 Wi-Fi Card Replacement, Battery: step 1, image 2 of 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Wi-Fi Card Replacement, Back Cover: step 2, image 1 of 1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 1 of 1
    • Lift up the two tabs connected to wires.
  4. HP ZBook 15 Wi-Fi Card Replacement: step 4, image 1 of 2 HP ZBook 15 Wi-Fi Card Replacement: step 4, image 2 of 2
    • Remove the two 3mm screws from the corners of the card with a Phillips #0 screwdriver.
    • Lift the card up and slide it out to disconnect it.
3 other people completed this guide.
Grant Terris
2,828 Reputation
12 Guides authored
Cal Poly, Team 8-43, Amido Winter 2015 Member of Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Members
15 Guides authored
One Comment
I’m planning to upgrade my Zbook by installing a Wireless AC-capable WiFi module. I’ve found a cheap one that’s compatible according to the service manual: the Intel 7260HMW. However, it doesn’t have an HP SPS, it seems to have come from a DELL laptop.
Has anyone tried this? Will it work? I guess I’ll find out the hard way!
Hopefully, the seller will allow me to test the adapter before buying.
Luis Alejandro Araúz - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 48
All Time: 5,477
