Introduction
Is the screen on your laptop malfunctioning? Here are some possible problems with your screen. If you determine that the screen needs to be replaced, follow this replacement guide!
Flip the laptop over.
Slide the lever with the battery symbol beside it firmly until the battery pops out.
Remove the battery from the laptop.
Orient the laptop keyboard-side up.
Use tweezers to remove the adhesive covers for the screws.
Remove the four 3mm screws with a Phillips #0 screwdriver near the corners of the screen to remove the display.
Gently lower the screen and lay it face down on the keyboard.
Lift the corners of the tape closest to the top of the screen and peel toward the center carefully.
Slowly pull the tape away from the sides.
Lift the tape and disconnect the screen connector.
