HP ZBOOK 15 G5 LCD Replacement
  1. HP ZBOOK 15 G5 LCD Replacement, Opening the Bottom Panel: step 1, image 1 of 1
    • Find the bottom panel locking mechanism
    • Move the switch to the right to unlock and slide it in a downwards fashion
  2. HP ZBOOK 15 G5 LCD Replacement, Removing the Battery: step 2, image 1 of 1
    • Slide the battery latches to the right to loosen the battery
    • Remove the battery and place it to the side
  3. HP ZBOOK 15 G5 LCD Replacement, Removing the Bottom Case: step 3, image 1 of 1
    • Remove the keyboard screws
    • Remove these screws with a T8 screwdriver
    • Remove these screws with a philips screwdriver
    • Once they are removed, carefully lift up the bottom case
  4. HP ZBOOK 15 G5 LCD Replacement, Removing SSD and LCD Connector Cover: step 4, image 1 of 1
    • Unscrew SSD screw and slide the SSD out
    • Remove these screws and place the LCD connector cover to the side
    • Disconnect all of the motherboard connectors
  5. HP ZBOOK 15 G5 LCD Replacement, Removing the LCD: step 5, image 1 of 1
    • Unscrew the 6 LCD screws to the top left and right
    • Once removed, carefully remove the LCD
    • Tip: Remove two screws from each side and then place the laptop on it's side. Unscrew the final two and separate the LCD and Top Case
    • Screw the new LCD in and make sure to connect all of the LCD connectors
    • Screw the bottom case back onto the laptop
    • Connect the battery and put the battery cover back into place
Once the repair had been done. Call the user and let them know their laptop is ready for pick-up
4 other people completed this guide.
Ved Pitre
1,248 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 41
Past 30 Days: 125
All Time: 9,625
