Installing HP TouchPad Motherboard Assembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing HP TouchPad Motherboard Assembly, Motherboard Assembly: step 1, image 1 of 1
    • If present, remove the two pieces of tape boxed in red.
  2. Installing HP TouchPad Motherboard Assembly: step 2, image 1 of 2 Installing HP TouchPad Motherboard Assembly: step 2, image 2 of 2
    • Use the edge of a plastic opening tool to flip up the retaining flap on the volume control/power button ribbon cable socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the cable out of its socket.
  3. Installing HP TouchPad Motherboard Assembly: step 3, image 1 of 1
    • Use a plastic opening tool to lift the camera connector up and out of its socket on the motherboard.
    • Bend the camera cable away from the motherboard.
  4. Installing HP TouchPad Motherboard Assembly: step 4, image 1 of 2 Installing HP TouchPad Motherboard Assembly: step 4, image 2 of 2
    • Carefully flip up the retaining flap on the microphone cable socket.
    • Be sure you are prying up on the hinged retaining flap.
    • Pull the microphone cable out of its socket.
  5. Installing HP TouchPad Motherboard Assembly: step 5, image 1 of 1
    • Use your plastic opening tool to pry the upper antenna connector up from its socket on the motherboard.
  6. Installing HP TouchPad Motherboard Assembly: step 6, image 1 of 2 Installing HP TouchPad Motherboard Assembly: step 6, image 2 of 2
    • Pry up the retaining flap on the headphone jack ribbon cable socket.
    • Pull the headphone jack ribbon cable out of its socket.
  7. Installing HP TouchPad Motherboard Assembly: step 7, image 1 of 1
    • Pry the speaker cable connector up from its socket on the motherboard.
    • Pry up from beneath the wires.
  8. Installing HP TouchPad Motherboard Assembly: step 8, image 1 of 2 Installing HP TouchPad Motherboard Assembly: step 8, image 2 of 2
    • Use a plastic opening tool to flip up the retaining flap on the digitizer board ribbon cable socket.
    • Pull the digitizer ribbon cable out of its socket.
  9. Installing HP TouchPad Motherboard Assembly: step 9, image 1 of 1
    • Pry up the lower antenna cable connector from its socket on the motherboard.
  10. Installing HP TouchPad Motherboard Assembly: step 10, image 1 of 1
    • De-route the lower antenna cable along the top edge of the battery and carefully pull it out from under its retaining clip near the top right corner of the battery.
  11. Installing HP TouchPad Motherboard Assembly: step 11, image 1 of 1
    • Remove the eight 3.2 mm Phillips screws securing both the battery and the motherboard to the rear case.
  12. Installing HP TouchPad Motherboard Assembly: step 12, image 1 of 2 Installing HP TouchPad Motherboard Assembly: step 12, image 2 of 2
    • Use a plastic opening tool to pry the battery up from the tape securing it to the rear case.
    • It is easiest to pry up along the edges of the battery closest to the USB connector and the digitizer board.
  13. Installing HP TouchPad Motherboard Assembly: step 13, image 1 of 1
    • Lift the motherboard assembly out of the rear case, minding any cables that may get caught.
  14. Installing HP TouchPad Motherboard Assembly: step 14, image 1 of 2 Installing HP TouchPad Motherboard Assembly: step 14, image 2 of 2
    • Carefully pull the battery away from the L-shaped motherboard to disconnect its cable.
    • Remove the battery from the motherboard.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 987
