This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
HP Tango X Power Adapter Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
64
All Time:
775
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
The printer stopped responding to power-on attempts and was no longer emitting any light. We suspected a power supply issue. It turned out that the power adapter was only providing the 32 V output. The 12 V output was missing. The power adapter was simply replaced.
    1. HP Tango X Power Adapter Replacement, Opening the housing: step 1, image 1 of 3 HP Tango X Power Adapter Replacement, Opening the housing: step 1, image 2 of 3 HP Tango X Power Adapter Replacement, Opening the housing: step 1, image 3 of 3
      • Behind each of the round stickers is a Torx screw.
      • Use a screwdriver to release the 8 clips. These are evenly distributed around the device. To do this, pry off the light gray cover bit by bit.
      Ask FixBot
    2. HP Tango X Power Adapter Replacement, Power supply replacement: step 2, image 1 of 2 HP Tango X Power Adapter Replacement, Power supply replacement: step 2, image 2 of 2
      • The power supply is held loosely in the housing and is connected by a 3-pin connector.
      • When unplugging the connector, pull directly on the connector, not on the cables.
      • The power supply can be tested using a multimeter. There should be 12 V or 32 V between the center connector pin and the outer pins. Naturally, the power supply must be connected to a wall outlet with the power cable for this to work.
      • A replacement power supply can be ordered from several suppliers online for under €20.
      Ask FixBot
    3. HP Tango X Power Adapter Replacement, remaining images: step 3, image 1 of 3 HP Tango X Power Adapter Replacement, remaining images: step 3, image 2 of 3 HP Tango X Power Adapter Replacement, remaining images: step 3, image 3 of 3
      • Here are a few more images.
      Ask FixBot
Follow these steps in reverse order to reassemble your device.
Andreas Reheis
4,218 Reputation
28 Guides authored
DerToaster Member of DerToaster
Local Repair Groups
6 Members
432 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 64
All Time: 775
