HP Stream 8 Rear-facing camera Replacement
  1. HP Stream 8 Rear-facing camera Replacement, Midframe: step 1, image 1 of 1
    • Use your nail or a spudger to pry the back cover off of the device.
  2. HP Stream 8 Rear-facing camera Replacement: step 2, image 1 of 1
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Rear-facing camera Replacement: step 3, image 1 of 1
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Rear-facing camera Replacement: step 4, image 1 of 1
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Rear-facing camera Replacement, Rear-Facing Camera: step 5, image 1 of 1
    • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
  6. HP Stream 8 Rear-facing camera Replacement: step 6, image 1 of 1
    • Remove the back facing camera with the tweezers.
Nick Miller
669 Reputation
6 Guides authored
Cal Poly, Team 34-14, Maness Spring 2016 Member of Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 223
