HP Stream 14-CB174WM Wi-Fi Card Replacement
  1. HP Stream 14-CB174WM Wi-Fi Card Replacement, Lower Case: step 1, image 1 of 2 HP Stream 14-CB174WM Wi-Fi Card Replacement, Lower Case: step 1, image 2 of 2
    • Use an opening pick to gently pry up the edge of the rubber foot.
    • Grab the lifted edge of the foot and gently pull it away.
    • Repeat for the other rubber foot.
    • The oils on your skin can damage the adhesive on the rubber feet. Try not to touch the adhesive part of the feet with your hands.
  2. HP Stream 14-CB174WM Wi-Fi Card Replacement: step 2, image 1 of 2 HP Stream 14-CB174WM Wi-Fi Card Replacement: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the eight 6.6 mm screws that secure the lower case.
  3. HP Stream 14-CB174WM Wi-Fi Card Replacement: step 3, image 1 of 3 HP Stream 14-CB174WM Wi-Fi Card Replacement: step 3, image 2 of 3 HP Stream 14-CB174WM Wi-Fi Card Replacement: step 3, image 3 of 3
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the opening pick around the perimeter, prying every couple of centimeters as you go.
    • You will hear "snaps" of the lower case retaining clips releasing.
    • Continue prying around the entire perimeter until the lower case fully releases.
    • Lift off the lower case.
  4. HP Stream 14-CB174WM Wi-Fi Card Replacement, Battery: step 4, image 1 of 3 HP Stream 14-CB174WM Wi-Fi Card Replacement, Battery: step 4, image 2 of 3 HP Stream 14-CB174WM Wi-Fi Card Replacement, Battery: step 4, image 3 of 3
    • Remove the following Phillips screws that secure the battery:
    • Three 2.9 mm
    • Two 6.8 mm
    • Be sure to keep different screw types separate from one another throughout the battery removal process.
  5. HP Stream 14-CB174WM Wi-Fi Card Replacement: step 5, image 1 of 2 HP Stream 14-CB174WM Wi-Fi Card Replacement: step 5, image 2 of 2
    • Use your fingers or the point of a spudger to slowly “wiggle” the battery connector directly out of its socket.
    • Do not pull on the wires.
  6. HP Stream 14-CB174WM Wi-Fi Card Replacement: step 6, image 1 of 2 HP Stream 14-CB174WM Wi-Fi Card Replacement: step 6, image 2 of 2
    • Gently unseat the battery connector wire out from under the two plastic tabs.
  7. HP Stream 14-CB174WM Wi-Fi Card Replacement: step 7, image 1 of 2 HP Stream 14-CB174WM Wi-Fi Card Replacement: step 7, image 2 of 2
    • Lift the battery up and out of the laptop.
    • The battery should lift out with very little effort. If the battery cannot easily be lifted out of the laptop chassis, check to see if you missed any screws.
  8. HP Stream 14-CB174WM Wi-Fi Card Replacement, Wi-Fi Card: step 8, image 1 of 2 HP Stream 14-CB174WM Wi-Fi Card Replacement, Wi-Fi Card: step 8, image 2 of 2
    • Locate the Wi-Fi card module near the top of the laptop.
    • It is right above the large copper heat sink.
  9. HP Stream 14-CB174WM Wi-Fi Card Replacement: step 9, image 1 of 2 HP Stream 14-CB174WM Wi-Fi Card Replacement: step 9, image 2 of 2
    • Use a plastic opening tool to gently lift and detach the two Wi-Fi card antenna cables.
    • Each wire features numbered tags (1 and 2) corresponding to identical numbers printed on the card. These numbers indicate the designated ports on the wifi card where each wire should be plugged in.
  10. HP Stream 14-CB174WM Wi-Fi Card Replacement: step 10, image 1 of 1
    • Remove the single screw that secures the Wi-Fi card using a Phillips screwdriver.
  11. HP Stream 14-CB174WM Wi-Fi Card Replacement: step 11, image 1 of 2 HP Stream 14-CB174WM Wi-Fi Card Replacement: step 11, image 2 of 2
    • Pull the card directly out of its socket.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 23
All Time: 280
