HP Stream 14-CB174WM Lower Case Replacement
  1. HP Stream 14-CB174WM Lower Case Replacement, Lower Case: step 1, image 1 of 2 HP Stream 14-CB174WM Lower Case Replacement, Lower Case: step 1, image 2 of 2
    • Use an opening pick to gently pry up the edge of the rubber foot.
    • Grab the lifted edge of the foot and gently pull it away.
    • Repeat for the other rubber foot.
    • The oils on your skin can damage the adhesive on the rubber feet. Try not to touch the adhesive part of the feet with your hands.
  2. HP Stream 14-CB174WM Lower Case Replacement: step 2, image 1 of 2 HP Stream 14-CB174WM Lower Case Replacement: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the eight 6.6 mm screws that secure the lower case.
  3. HP Stream 14-CB174WM Lower Case Replacement: step 3, image 1 of 3 HP Stream 14-CB174WM Lower Case Replacement: step 3, image 2 of 3 HP Stream 14-CB174WM Lower Case Replacement: step 3, image 3 of 3
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the opening pick around the perimeter, prying every couple of centimeters as you go.
    • You will hear "snaps" of the lower case retaining clips releasing.
    • Continue prying around the entire perimeter until the lower case fully releases.
    • Lift off the lower case.
Connor Bassolino
17,370 Reputation
74 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,640 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 174
