Introduction
If you notice your laptop no longer keeping a charge, you may need to replace the battery. This device is kind of strange because the battery isn't one of the first things you remove. This makes it hazardous because you may accidentally turn on your laptop while taking it apart. So be careful when removing the cover and use caution around the power button to ensure you don't turn it on.
Pry off the two elliptical rubber inserts (one in each corner).
Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
Turn the computer upright and lift the screen.
Carefully use a spudger to pry the plastic keyboard cover from the base.
Work the spudger around the cover to release the clips attaching the cover to the base.
Disconnect the cable connecting the ClickPad to the base.
Remove the plastic keyboard cover.
The character who made this tutorial shows in a couple of these pictures he/she destroyed the keyboard/top bezel. The keyboard is NOT meant to be detached from the mouse bezel, he/she popped every single chassis mounted plastic rivet that keeps every keyboard key centered within their hole in the bezel. In othe rwords mounting that prevents key malfunction. I haven't seen a keyboard detachable bezel in laptop design since the late 2000s.
Tilt the top of the keyboard plate up until you separate it from the base.
Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
Remove any tape covering the battery connector.
Disconnect the battery cable from its socket on the motherboard.
22 other people completed this guide.
4 Comments
Thank you for the guide. For us it was enough to unplug the battery and then plug it back in. The problem we encountered was that the capslock would blink on startup for the HP Stream 11.
Would this fix work for a HP notebook Model 11-N012NA. ?
Would this work for my House notebook PC 11-d011wm?
If I put the charger the thing will Will just start blinking
