Introduction
This guide instructs you on how to remove and replace the heatsink and fan assembly in a HP Spectre x360 13t-4000. Replacement of the heatsink may be necessary if the laptop is overheating.
Turn off and unplug the laptop.
Flip over the laptop so that the bottom backplate is exposed.
Use a Phillips #0 Screwdriver to remove the four circled 3 mm screws.
Use the same screwdriver to remove the circled 4 mm screw.
Almost done!
