HP Spectre x2 12-a002dx Battery Replacement
  1. HP Spectre x2 12-a002dx Battery Replacement, Screen: step 1, image 1 of 1
    • Make sure the device is powered off and the kick stand is retracted.
    • The HP Spectre should be placed on a flat surface with the keyboard detached.
  2. HP Spectre x2 12-a002dx Battery Replacement: step 2, image 1 of 3 HP Spectre x2 12-a002dx Battery Replacement: step 2, image 2 of 3 HP Spectre x2 12-a002dx Battery Replacement: step 2, image 3 of 3
    • To remove the screen, there is an entire system of clips which need to be undone as well as 4 Phillips M1.5x2.7 screws.
    • The screws should be removed using a Phillips #000 screwdriver. There is a sticker where the laptop attaches to the keyboard.
    • Heat the sticker (if needed) and use fine point tweezers to grip the sticker and remove it.
  3. HP Spectre x2 12-a002dx Battery Replacement: step 3, image 1 of 3 HP Spectre x2 12-a002dx Battery Replacement: step 3, image 2 of 3 HP Spectre x2 12-a002dx Battery Replacement: step 3, image 3 of 3
    • Use the plastic opening tools or insert a spudger to begin unclipping the system.
    • Pry the screen off once all the clips have been unclipped.
    • The screen may shatter if not already shattered (beware of flying glass).
    • This screen will break. There is double tape underneath the frame, which is not listed in here.
  4. HP Spectre x2 12-a002dx Battery Replacement: step 5, image 1 of 3 HP Spectre x2 12-a002dx Battery Replacement: step 5, image 2 of 3 HP Spectre x2 12-a002dx Battery Replacement: step 5, image 3 of 3
    • Remove the connecting cable of the screen and battery. Use a spudger to reveal the adhesive strip and carefully peel it off.
    • Insert a spudger to the other end and release the ZIF connectors. Detach the cable.
    • While a metal spudger is pictured, use a black nylon spudger instead because it is ESD safe.
  5. HP Spectre x2 12-a002dx Battery Replacement, Battery: step 6, image 1 of 1
    • The battery for this device is under the screen and takes up most of the space.
  6. HP Spectre x2 12-a002dx Battery Replacement: step 7, image 1 of 3 HP Spectre x2 12-a002dx Battery Replacement: step 7, image 2 of 3 HP Spectre x2 12-a002dx Battery Replacement: step 7, image 3 of 3
    • Pull the wire gently towards the connector.
    • Then, disconnect the wire and remove it from the device.
  7. HP Spectre x2 12-a002dx Battery Replacement: step 8, image 1 of 2 HP Spectre x2 12-a002dx Battery Replacement: step 8, image 2 of 2
    • Remove the six Phillips M2.0×3.5 screws connecting the battery to the device using the JIS 00 screwdriver.
    • Make sure to keep the screws in a safe place. You will need to use them to secure the replacement battery back in place.
  8. HP Spectre x2 12-a002dx Battery Replacement: step 9, image 1 of 2 HP Spectre x2 12-a002dx Battery Replacement: step 9, image 2 of 2
    • Use the tip of a spudger to push the battery connector out of its socket.
    • It helps to "walk" the connector out by pressing first on one side, then the other.
  9. HP Spectre x2 12-a002dx Battery Replacement: step 10, image 1 of 2 HP Spectre x2 12-a002dx Battery Replacement: step 10, image 2 of 2
    • Lift up the side of the battery that isn't glued down with adhesive
    • Use the spatula to gently scrape away the adhesive while applying a gentle upward pressure to help break the adhesive bonds.
    • A metal spudger was used again as pictured, but the black nylon spudger would be more appropriate to use.
  10. HP Spectre x2 12-a002dx Battery Replacement: step 11, image 1 of 1
    • Finally remove the old battery.
4 other people completed this guide.
Talha Bin Amir
683 Reputation
5 Guides authored
USF Tampa, Team S10-G6, Thompson Fall 2017 Member of USF Tampa, Team S10-G6, Thompson Fall 2017
USFT-THOMPSON-F17S10G6
4 Members
7 Guides authored
17 Comments
Awesome, thanks a lot! My old Spectre’s battery now only supports less than 2 hours, wish I could replace it with a new one.
Claud Monet - Reply
Clear - Complete - Accurate instructions led me through the successful replacement. glad I found this. Good Job.
Mayne Mihacsi - Reply
Did the screen crack for you
Tiffany -
Where can the replacement battery be purchased?
Jay Mac - Reply
Did the screen crack for anyone?
Tiffany - Reply
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 46
All Time: 12,347
