HP Spectre 13-4002dx SD Card Reader Replacement
  1. HP Spectre 13-4002dx SD Card Reader Replacement, Bottom Case: step 1, image 1 of 2 HP Spectre 13-4002dx SD Card Reader Replacement, Bottom Case: step 1, image 2 of 2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx SD Card Reader Replacement: step 2, image 1 of 2 HP Spectre 13-4002dx SD Card Reader Replacement: step 2, image 2 of 2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx SD Card Reader Replacement, Battery: step 3, image 1 of 3 HP Spectre 13-4002dx SD Card Reader Replacement, Battery: step 3, image 2 of 3 HP Spectre 13-4002dx SD Card Reader Replacement, Battery: step 3, image 3 of 3
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. HP Spectre 13-4002dx SD Card Reader Replacement: step 4, image 1 of 3 HP Spectre 13-4002dx SD Card Reader Replacement: step 4, image 2 of 3 HP Spectre 13-4002dx SD Card Reader Replacement: step 4, image 3 of 3
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  5. HP Spectre 13-4002dx SD Card Reader Replacement: step 5, image 1 of 2 HP Spectre 13-4002dx SD Card Reader Replacement: step 5, image 2 of 2
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  6. HP Spectre 13-4002dx SD Card Reader Replacement: step 6, image 1 of 3 HP Spectre 13-4002dx SD Card Reader Replacement: step 6, image 2 of 3 HP Spectre 13-4002dx SD Card Reader Replacement: step 6, image 3 of 3
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  7. HP Spectre 13-4002dx SD Card Reader Replacement: step 7, image 1 of 1
    • Carefully remove the battery.
  8. HP Spectre 13-4002dx SD Card Reader Replacement, SD Card Reader: step 8, image 1 of 3 HP Spectre 13-4002dx SD Card Reader Replacement, SD Card Reader: step 8, image 2 of 3 HP Spectre 13-4002dx SD Card Reader Replacement, SD Card Reader: step 8, image 3 of 3
    • The SD Card Port is located in the red box.
    • Remove the one PH0 30 mm screw circled in red.
  9. HP Spectre 13-4002dx SD Card Reader Replacement: step 9, image 1 of 1
    • Remove the connector outlined in red.
  10. HP Spectre 13-4002dx SD Card Reader Replacement: step 10, image 1 of 3 HP Spectre 13-4002dx SD Card Reader Replacement: step 10, image 2 of 3 HP Spectre 13-4002dx SD Card Reader Replacement: step 10, image 3 of 3
    • To unlock the ribbon cable, lift the white flap on the ZIF connector 90 degrees.
    • Slide the ribbon cable out of the connector.
  11. HP Spectre 13-4002dx SD Card Reader Replacement: step 11, image 1 of 1
    • Remove the SD Card Port.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 241
