HP Spectre 13-3010dx Back Case Removal
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. HP Spectre 13-3010dx Back Case Removal, Removal of the Back Case: step 1, image 1 of 2 HP Spectre 13-3010dx Back Case Removal, Removal of the Back Case: step 1, image 2 of 2
    • Put on Anti Static Wrist Strap.
    • It is always a good idea to ground yourself when working with electronics to prevent static buildup. You wear this strap to protect you and your device from accidental electrostatic discharge (ESD) damage during repairs.]
    • Flip Computer Upside down.
    • Unscrew the eight 3.3mm black screws on the back casing with the T4 Torx Screwdriver.
  2. HP Spectre 13-3010dx Back Case Removal: step 2, image 1 of 2 HP Spectre 13-3010dx Back Case Removal: step 2, image 2 of 2
    • Use the plastic opening tool to lift the back case off.
    • Use the plastic opening tools first; metal spudgers can damage your device.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 59
