HP Spectre 13 4003dx x360 Display Assembly Replacement
  1. HP Spectre 13 4003dx x360 Display Assembly Replacement, Battery: step 1, image 1 of 2 HP Spectre 13 4003dx x360 Display Assembly Replacement, Battery: step 1, image 2 of 2
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Turn the computer upside down.
    • Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
    • Make sure to use the magnetic project mat to help you keep track of the small screws.
  2. HP Spectre 13 4003dx x360 Display Assembly Replacement: step 2, image 1 of 2 HP Spectre 13 4003dx x360 Display Assembly Replacement: step 2, image 2 of 2
    • Use an opening tool to pry up and loosen the back case from the laptop.
    • If the back case doesn't loosen easily, there may be screws hidden underneath the rubber feet. Carefully pry a foot up and remove any hidden screws.
    • Remove the back case.
  3. HP Spectre 13 4003dx x360 Display Assembly Replacement: step 3, image 1 of 2 HP Spectre 13 4003dx x360 Display Assembly Replacement: step 3, image 2 of 2
    • Remove the four 2mm Phillips #00 screws securing the battery.
    • The screw locations are marked by small white arrows on the battery.
  4. HP Spectre 13 4003dx x360 Display Assembly Replacement: step 4, image 1 of 3 HP Spectre 13 4003dx x360 Display Assembly Replacement: step 4, image 2 of 3 HP Spectre 13 4003dx x360 Display Assembly Replacement: step 4, image 3 of 3
    • Peel off the adhesive on the left side of the battery holding the speaker wire down.
    • Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
    • Carefully unplug the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the battery.
    • It is normal for your battery to flex and bend a bit where the wider section meets the narrower section.
  5. HP Spectre 13 4003dx x360 Display Assembly Replacement, Display Assembly: step 5, image 1 of 3 HP Spectre 13 4003dx x360 Display Assembly Replacement, Display Assembly: step 5, image 2 of 3 HP Spectre 13 4003dx x360 Display Assembly Replacement, Display Assembly: step 5, image 3 of 3
    • Remove the two 2mm Phillips #00 screws from the fan.
    • Disconnect the fan from the motherboard.
  6. HP Spectre 13 4003dx x360 Display Assembly Replacement: step 6, image 1 of 3 HP Spectre 13 4003dx x360 Display Assembly Replacement: step 6, image 2 of 3 HP Spectre 13 4003dx x360 Display Assembly Replacement: step 6, image 3 of 3
    • Using minimal force, disconnect both WiFi antennae cables.
    • Remove the single Phillips #00 screw that secures the WiFi card.
    • Slide the WiFi card up until it is completely removed.
    • Do not pull up on the wireless module while it is still seated. You may inadvertently damage it.
  7. HP Spectre 13 4003dx x360 Display Assembly Replacement: step 7, image 1 of 2 HP Spectre 13 4003dx x360 Display Assembly Replacement: step 7, image 2 of 2
    • Using the PH00 Screwdriver, Remove the four hinge screws.
  8. HP Spectre 13 4003dx x360 Display Assembly Replacement: step 8, image 1 of 2 HP Spectre 13 4003dx x360 Display Assembly Replacement: step 8, image 2 of 2
    • Grip the black tape and pull up to unplug.
  9. HP Spectre 13 4003dx x360 Display Assembly Replacement: step 9, image 1 of 1
    • Separate the display assembly from the body of the computer.
    • As a result of the orientation of the hinges, you may need to rotate open the laptop to around 270 degrees to clear them.
Ethan Plumer
605 Reputation
2 Guides authored
USF Tampa, Team S5-G4, Passmore Spring 2018 Member of USF Tampa, Team S5-G4, Passmore Spring 2018
USFT-PASSMORE-S18S5G4
3 Members
8 Guides authored
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 65
All Time: 9,791
