Introduction
This guide will give you step-by-step instructions on how to remove your battery. Make sure you have a clean, dry, uncluttered, and roomy work space that has good lighting before you start. Also, make sure that your battery actually needs to be replaced by consulting our troubleshooting guide.
Tool used on this step:Magnetic Project Mat$19.95
Turn the computer upside down.
Use the T4 Torx Screwdriver to remove the eight 3.3 mm screws.
Use an opening tool to pry up and loosen the back case from the laptop.
Remove the back case.
Peel off the adhesive on the left side of the battery holding the speaker wire down.
Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
Carefully unplug the battery by pulling the connector towards the battery.
Remove the battery.
