Introduction
This guide will give you step-by-step instructions on how to remove your battery. Make sure you have a clean, dry, uncluttered, and roomy work space that has good lighting before you start. Also, make sure that your battery actually needs to be replaced by consulting our troubleshooting guide.
Tool used on this step:Magnetic Project Mat$19.95
Turn the computer upside down.
Use the T4 Torx Screwdriver to remove the eight 3.3 mm screws.
Peel off the adhesive holding the right speaker wire down.
Move the battery slightly to gain access to the battery plug.
Unplug then remove the battery.
