HP ProOne 600 G1 Fan Replacement
  1. HP ProOne 600 G1 Fan Replacement, Back Removal: step 1, image 1 of 2 HP ProOne 600 G1 Fan Replacement, Back Removal: step 1, image 2 of 2
    • Push the unlock tabs on the back of the monitor in and towards each other while sliding the back cover up.
  2. HP ProOne 600 G1 Fan Replacement: step 2, image 1 of 2 HP ProOne 600 G1 Fan Replacement: step 2, image 2 of 2
    • Loosen the two 1/2" screws , with the T15 Torx Screwdriver, on each side of the stand. Remove stand.
  3. HP ProOne 600 G1 Fan Replacement: step 3, image 1 of 1
    • Take out the single 3/8" screw, with the T15 Torx Screwdriver, from the middle of the backplate.
  4. HP ProOne 600 G1 Fan Replacement: step 4, image 1 of 1
    • Remove the backplate by pulling it back towards you.
    • Small plastic tabs hold in the backplate, pull these up to remove it.
  5. HP ProOne 600 G1 Fan Replacement, Fan: step 5, image 1 of 3 HP ProOne 600 G1 Fan Replacement, Fan: step 5, image 2 of 3 HP ProOne 600 G1 Fan Replacement, Fan: step 5, image 3 of 3
    • Remove both 3/8" screws using the T15 Torx Screwdriver from the metal plate, and slide the plate to the left.
  6. HP ProOne 600 G1 Fan Replacement: step 6, image 1 of 3 HP ProOne 600 G1 Fan Replacement: step 6, image 2 of 3 HP ProOne 600 G1 Fan Replacement: step 6, image 3 of 3
    • Unscrew three surrounding 1/4" screws, with the T15 Torx Screwdriver. Pull out the fan and attached wires.
Victor Chacon
113 Reputation
1 Guide authored
Cal Poly, Team 1-20, Maness Fall 2015 Member of Cal Poly, Team 1-20, Maness Fall 2015
CPSU-MANESS-F15S1G20
4 Members
12 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 33
All Time: 1,882
