Introduction
Many repairs for the HP ProBook 640 G5 require access to internal components such as the RAM, SSD, HDD, battery, and WLAN module. This guide will show you how to properly remove the bottom cover so you can proceed with additional repair steps. This is a prerequisite guide for most component replacements on this device. Before starting, power off the laptop completely and disconnect all power sources.
Shut down the HP ProBook 640 G5 completely.
Disconnect the power adapter and all connected peripherals.
Press and hold the power button for 5 seconds to discharge remaining electricity.
Flip the laptop over so the bottom is facing up.
Loosen eight silver 6mm screws using a Phillips #0 screwdriver.
Remove two black 6mm screws using a TR7 Torx screwdriver.
Insert a plastic opening tool into the seam and gently pry around the edges.
Lift the bottom cover away from the laptop.
