Introduction
Go to step 1 ↓This guide will walk you through the process of replacing the RAM (Random Access Memory) for your HP ProBook 640 G1 laptop. If you notice your computer running slowly, or you notice it has a hard time running multiple tasks at once, it may be time to upgrade your RAM.
Tools
Remove the eight rubber screw plugs from the bottom and the two rubber screw plugs from the sides of the laptop using a paperclip.
Remove the fourteen 6 mm screws from the bottom of the laptop and the two 6 mm screws from the sides using a T8 Torx screwdriver.
Remove the six 4 mm screws that secure the midframe using a T8 Torx screwdriver.
Gently push the clasps securing the RAM outwards and down to free the RAM.
Gently grab the sides of the RAM stick and remove it from its socket by pulling it to the right.
Repeat this process for the second RAM stick located underneath the first.
