Introduction
Go to step 1 ↓This guide will walk you through the process of replacing the cooling fan in the HP ProBook 640 G1 laptop. A faulty fan can lead to overheating, loud noises, or reduced system performance. Before beginning this repair, check our Troubleshooting page to see if your issue can be resolved without replacing the fan.
This repair requires removing the battery, service cover, and fan assembly. Always make sure the laptop is fully powered off and not in sleep mode. Disconnect the charger and any external devices before starting.
Remove the eight rubber screw plugs from the bottom and the two rubber screw plugs from the sides of the laptop using a paperclip.
Remove the fourteen 6 mm screws from the bottom of the laptop and the two 6 mm screws from the sides using a T8 Torx screwdriver.
Remove the six 4 mm screws that secure the midframe using a T8 Torx screwdriver.
