Introduction
If your laptop screen is cracked or appears dark while the computer is running, replace the screen.
Flip the 4520s upside-down with the front toward you.
Push the two latches below the battery inwards at the same time.
Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
Flip the 4520s over and rotate it so the back is facing you.
Use a metal spudger to peel off two rubber caps located on either side of the battery port.
Rotate the 4520s and then open it with the screen facing you.
The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
Lift the switch cover away from the 4520s and set it aside.
Pry open the tabs behind the border of the screen using a metal spudger.
Set the border of the screen aside.
Use a Torx (T9) head screwdriver to remove two 5mm screws above the screen, and two more screws below it.
Above the screen is a bronze port with a cable connected to it. Disconnect the cable using a metal spudger or your finger.
Use a Phillips (PH1) head screwdriver to remove eight 2mm screws from the screen. Four of the screws will be on the left side and four will be on the right.
Place the screen face down.
To open the clamp for the ribbon cable, use a spudger to pry up the metal bar securing it to the screen.
Disconnect the cable after freeing it from the metal bar
