Introduction
If your 4520s can't read CD's or DVD's, you might have a faulty optical drive. Replacing the optical drive may solve the problem.
Flip the 4520s upside-down with the front toward you.
Push the two latches below the battery inwards at the same time.
Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
Flip the 4520s over and rotate it so the back is facing you.
Use a metal spudger to peel off two rubber caps located on either side of the battery port.
Rotate the 4520s and then open it with the screen facing you.
The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
Lift the switch cover away from the 4520s and set it aside.
Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
Gently raise up the keyboard and flip it over to reveal a ribbon cable.
Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
Remove the cable and lift the keyboard panel up. Set it aside.
The housing for the optical drive is on the right of the device.
Remove the 5mm screw on the left side of the metal plate with a Phillips (PH1) head screwdriver.
Use a Phillips (PH1) head screwdriver to remove two 2mm screws securing the metal tab to the optical drive.
