1988-1994 Chevrolet Cavalier Ignition Switch (Lock Cylinder Seperate) Replacement
Views: 15K
View statistics:
Past 24 Hours:
4
Past 7 Days:
42
Past 30 Days:
112
All Time:
14,813
Comments: 6
6 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide, you will learn how to fix the ignition switch of your Chevrolet Cavalier (1988-1994). You will need two tools in order to complete the replacement. The links for these can be found below under “Tools.” It is also necessary to purchase a new ignition switch which link can be found under “Parts.” This repair should fix any issues you may be having with an ignition switch (car not turning on, stuck keys, etc.). Please keep in mind that this repair can only be made on models that do not contain an airbag behind the steering wheel.
Tools
    1. 1988-1994 Chevrolet Cavalier Ignition Switch (Lock Cylinder Seperate) Replacement, Ignition Switch (Lock Cylinder Seperate): step 1, image 1 of 1
      • Before beginning, ensure that your model does not contain an airbag behind the steering wheel. Then, disconnect your car battery.
      • Pull off your horn button and locate the horn wire. Once found, twist the plastic keeper to remove.
      Ask FixBot
    2. 1988-1994 Chevrolet Cavalier Ignition Switch (Lock Cylinder Seperate) Replacement: step 2, image 1 of 1
      • Locate the six "torx head" screws that hold the steering wheel to the steering wheel hub. Removing the screws is not necessary but will make the job easier.
      Ask FixBot
    3. 1988-1994 Chevrolet Cavalier Ignition Switch (Lock Cylinder Seperate) Replacement: step 3, image 1 of 1
      • Remove the steering shaft nut and pull off the steering hub. A steering wheel puller may be required. Use caution as the steering hub may pop loose. Next, remove the two "torx head" screws behind the steering hub that hold the two plastic covers together.
      Ask FixBot
    4. 1988-1994 Chevrolet Cavalier Ignition Switch (Lock Cylinder Seperate) Replacement: step 4, image 1 of 1
      • Remove the top half of the plastic cover with a strong pull.
      Ask FixBot
    5. 1988-1994 Chevrolet Cavalier Ignition Switch (Lock Cylinder Seperate) Replacement: step 5, image 1 of 1
      • Using locking pliers, unscrew the tilt-adjusting lever. Wrap a shop towel or dish cloth around the lever to prevent scratches.
      Ask FixBot
    6. 1988-1994 Chevrolet Cavalier Ignition Switch (Lock Cylinder Seperate) Replacement: step 6, image 1 of 1
      • Remove the three "torx head" screws to release the plastic cover from the steering column.
      Ask FixBot
    7. 1988-1994 Chevrolet Cavalier Ignition Switch (Lock Cylinder Seperate) Replacement: step 7, image 1 of 2 1988-1994 Chevrolet Cavalier Ignition Switch (Lock Cylinder Seperate) Replacement: step 7, image 2 of 2
      • Sit in the car facing the steering wheel. Lean to the left to locate the two "torx head" screws on the ignition. Remove these.
      Ask FixBot
    8. 1988-1994 Chevrolet Cavalier Ignition Switch (Lock Cylinder Seperate) Replacement: step 8, image 1 of 1
      • Using a flat head screwdriver, test the new switch. Do so by reconnecting the battery and turning the switch in either direction. The switch should turn smoothly and only kick back to the on position. After testing, disconnect the battery again. Take note of the tab on the case of the switch.
      Ask FixBot
    9. 1988-1994 Chevrolet Cavalier Ignition Switch (Lock Cylinder Seperate) Replacement: step 9, image 1 of 1
      • Tab A goes into slot B, marked in the photo. Also note that just above the red circle is the end of the ignition lock cylinder in the off position. If yours is not in the off position, it should be.
      Ask FixBot
    10. 1988-1994 Chevrolet Cavalier Ignition Switch (Lock Cylinder Seperate) Replacement: step 10, image 1 of 1
      • Repeat the steps in opposite order to put the steering wheel back together.
      Ask FixBot
4 other people completed this guide.
islindsey
217 Reputation
1 Guide authored
6 Guide Comments
How to change out the key switch 94 Cavalier
eddie Richardson - Reply Share
Quick and easy fix! Thanks!
Terry Manning - Reply Share
Where can get a replacement ignition switch? Do stores carry them??
Forrest Sutton - Reply Share
how do you get the switch cylinder out of column
Mark A Branner - Reply Share
Hey, I have a 1991 Chevy Cavalier and sometimes the windshield wipers/radio/clock don't work. Does this sound familiar? Trying to understand what parts I may need to order to corect this.
Dennis Cernosia - Reply Share
Past 24 Hours: 4
Past 7 Days: 42
Past 30 Days: 112
All Time: 14,813
