Introduction
If you are trying to type and your keyboard is not responding or creating a response on your screen, replacing the keyboard might resolve this issue.
Make sure that your device is properly shut down and unplugged from any outlet.
Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
Press and slide up the battery release tab with your thumb until the battery pops out of place.
Using a Phillips #0 screwdriver, unscrew all four Phillips PM 2.5X13.0mm screws and place in a secure area until the end of the project.
Use the flat edge of the plastic spudger inserted under the bottom of the strip cover and pry upwards to un-clip the cover, starting at the right and moving to the left.
Use the J0 screwdriver to unscrew all (4) PM 2.5X13.0mm screws from the top of the keyboard and set aside.
Using your hands, lift the keyboard up from the top towards yourself until the keyboard is resting in your hand.
