HP Pavilion zd8000 Screen Replacement
  1. HP Pavilion zd8000 Screen Replacement, Battery: step 1, image 1 of 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Screen Replacement: step 2, image 1 of 2 HP Pavilion zd8000 Screen Replacement: step 2, image 2 of 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Screen Replacement, WiFi Card Cables: step 3, image 1 of 2 HP Pavilion zd8000 Screen Replacement, WiFi Card Cables: step 3, image 2 of 2
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  4. HP Pavilion zd8000 Screen Replacement: step 4, image 1 of 2 HP Pavilion zd8000 Screen Replacement: step 4, image 2 of 2
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
  5. HP Pavilion zd8000 Screen Replacement, Keyboard: step 5, image 1 of 1
    • Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
  6. HP Pavilion zd8000 Screen Replacement: step 6, image 1 of 2 HP Pavilion zd8000 Screen Replacement: step 6, image 2 of 2
    • Flip the laptop over and open the screen.
    • Push up on the four latches located at the top of the keyboard with the spudger to release them.
  7. HP Pavilion zd8000 Screen Replacement: step 7, image 1 of 2 HP Pavilion zd8000 Screen Replacement: step 7, image 2 of 2
    • Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable.
    • Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
  8. HP Pavilion zd8000 Screen Replacement: step 8, image 1 of 2 HP Pavilion zd8000 Screen Replacement: step 8, image 2 of 2
    • Rotate the keyboard so that the bottom is visible.
    • With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
    • Pull the tab towards you to release the keyboard from the laptop.
  9. HP Pavilion zd8000 Screen Replacement, Switch Cover: step 9, image 1 of 2 HP Pavilion zd8000 Screen Replacement, Switch Cover: step 9, image 2 of 2
    • Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
    • Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
  10. HP Pavilion zd8000 Screen Replacement: step 10, image 1 of 1
    • Flip the laptop over.
    • Fully open the laptop.
  11. HP Pavilion zd8000 Screen Replacement: step 11, image 1 of 3 HP Pavilion zd8000 Screen Replacement: step 11, image 2 of 3 HP Pavilion zd8000 Screen Replacement: step 11, image 3 of 3
    • Rotate it so the display is on your right and the keyboard is on your left.
    • Lift the switch cover firmly but slowly so you do not snap it.
    • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
    • The switch cover should easily separate from the laptop as you run the spudger through.
  12. HP Pavilion zd8000 Screen Replacement, Screen: step 12, image 1 of 2 HP Pavilion zd8000 Screen Replacement, Screen: step 12, image 2 of 2
    • Close the lid and rotate the laptop so that the vents are facing you.
    • Unscrew the two 8mm Philips screws below the hinges.
  13. HP Pavilion zd8000 Screen Replacement: step 13, image 1 of 2 HP Pavilion zd8000 Screen Replacement: step 13, image 2 of 2
    • Carefully rotate the laptop 90 degrees counter-clockwise and open the screen.
    • Pull on the black tab with the HP service sticker to unplug the display from the motherboard.
  14. HP Pavilion zd8000 Screen Replacement: step 14, image 1 of 2 HP Pavilion zd8000 Screen Replacement: step 14, image 2 of 2
    • Using tweezers, remove the black cable from the hole leading to the WiFi enclosure.
    • Pull gently to remove the black and grey cables from the case.
    • Check the surface beneath the laptop to ensure the cables do not catch on anything when you flip the laptop over.
  15. HP Pavilion zd8000 Screen Replacement: step 15, image 1 of 2 HP Pavilion zd8000 Screen Replacement: step 15, image 2 of 2
    • Using tweezers, pull the black cable towards the display and through the hole in the casing.
  16. HP Pavilion zd8000 Screen Replacement: step 16, image 1 of 3 HP Pavilion zd8000 Screen Replacement: step 16, image 2 of 3 HP Pavilion zd8000 Screen Replacement: step 16, image 3 of 3
    • Unscrew the two 8mm Philips screws that attach the hinge to the laptop's display.
    • Lift the screen upwards to detach it from the laptop.
Allie Menard
820 Reputation
13 Guides authored
Cal Poly, Team 24-56, Amido Spring 2011 Member of Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Members
13 Guides authored
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 26
All Time: 9,211
