HP Pavilion zd8000 CD/Optical Drive Replacement
  1. HP Pavilion zd8000 CD/Optical Drive Replacement, Battery: step 1, image 1 of 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 CD/Optical Drive Replacement: step 2, image 1 of 2 HP Pavilion zd8000 CD/Optical Drive Replacement: step 2, image 2 of 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 CD/Optical Drive Replacement, CD/Optical Drive: step 3, image 1 of 1
    • Remove the 8mm Philips screw located between the hard drive and the WiFi card.
  4. HP Pavilion zd8000 CD/Optical Drive Replacement: step 4, image 1 of 2 HP Pavilion zd8000 CD/Optical Drive Replacement: step 4, image 2 of 2
    • Turn the laptop 90 degrees clockwise so you are facing the CD drive.
    • Unbend a paperclip and insert the end into the small hole by the eject button to cause the tray to pop out towards you.
  5. HP Pavilion zd8000 CD/Optical Drive Replacement: step 5, image 1 of 2 HP Pavilion zd8000 CD/Optical Drive Replacement: step 5, image 2 of 2
    • Gently pull the tray away from the laptop and the rest of the optical drive will follow.
Allie Menard
820 Reputation
13 Guides authored
Cal Poly, Team 24-56, Amido Spring 2011 Member of Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Members
13 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 8
All Time: 3,425
