Introduction
If your laptop is unusually loud or warm, the fan may need to be replaced. To replace the fan, you will need to know how to use a screwdriver. Small parts (screws) may be a swallowing hazard for young children; keep all parts in a secure location.
Power off your device and disconnect all external devices connected to the laptop.
Remove the screws from the perimeter of the battery with a Phillips 00 Screwdriver.
3 Phillips 2.0 x 4.6 mm screws
Remove the screws from the perimeter of the motherboard with a Phillips 00 Screwdriver.
8 Phillips 2.0 x 4.7 mm screws.
Disconnect the bundle cable connector by gently gripping the cable wires and pulling outwards.
Katie, 10 stars on this. It 100% accurately describes the replacement of the whole keyboard deck including the kbd and the touchpad as one unit. Please put in a warning, the keyboards being sold that are only the keyboard poriton are not valid replacements. I have tried to do such a replacement of a $30 one and there is no way to separate the deck from the keyboard without damage. Again, kudos on this, i opened the computer with zero problems and then hit the wall. I will be buying a replacement deck with the kbd and pad - once assembled, diassembly and replacement is just not the way.
Ralph Brandt - Reply
