Introduction
To remove the laptop's speakers, many components within the laptop need to be removed. This is a guide to do so.
Slide the battery switch to the left until the battery unlatches from the base of the laptop.
Use the PH 00 screwdriver to unscrew the 2.5 mm screw to the right of the hard drive.
Pull the triangular blue tab to diconnect and remove the hard drive. You can see the word 'Pull' on the cover.
Insert a plastic spudger or similar pry tool, beneath the keyboard, near the "insert" key, and pop the keyboard up from the laptop.
Starting at the opening you just created, run your fingers around the outside of the keyboard separating it from the rest of the computer.
Slightly angle the keyboard back so the ribbon connector underneath it is visible.
Remove the ribbon cable by using your fingers to pull up and away from the connector.
With the laptop bottom facing up, locate the rubber plug on the right side of the computer.
Use a metal splunger to remove the plug.
Remove the ten 6.7 mm screws using a PH00 screwdriver.
Remove the five 3.4 mm screws using a PH00 screwdriver.
Flip the computer over and open it.
Detach the two purple ribbons from the ribbon connectors.
Unscrew the six 4.6 mm screws using the PH00 screwdriver.
Locate the red and black speaker cables connecting the speakers and detach them from the two holders.
