HP Pavilion dv7t-7000 Speaker Replacement
  1. HP Pavilion dv7t-7000 Speaker Replacement, Battery: step 1, image 1 of 1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Speaker Replacement: step 2, image 1 of 1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Speaker Replacement: step 3, image 1 of 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Speaker Replacement, Back Panel: step 4, image 1 of 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Speaker Replacement: step 5, image 1 of 2 HP Pavilion dv7t-7000 Speaker Replacement: step 5, image 2 of 2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Speaker Replacement, Keyboard: step 6, image 1 of 2 HP Pavilion dv7t-7000 Speaker Replacement, Keyboard: step 6, image 2 of 2
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
  7. HP Pavilion dv7t-7000 Speaker Replacement: step 7, image 1 of 3 HP Pavilion dv7t-7000 Speaker Replacement: step 7, image 2 of 3 HP Pavilion dv7t-7000 Speaker Replacement: step 7, image 3 of 3
    • Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
  8. HP Pavilion dv7t-7000 Speaker Replacement: step 8, image 1 of 1
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
  9. HP Pavilion dv7t-7000 Speaker Replacement, Speaker: step 9, image 1 of 3 HP Pavilion dv7t-7000 Speaker Replacement, Speaker: step 9, image 2 of 3 HP Pavilion dv7t-7000 Speaker Replacement, Speaker: step 9, image 3 of 3
    • Use Phillips #00 to unscrew the screw and take off the front panel.
  10. HP Pavilion dv7t-7000 Speaker Replacement: step 10, image 1 of 2 HP Pavilion dv7t-7000 Speaker Replacement: step 10, image 2 of 2
    • The speaker is located at the back side of the front panel.
    • Unscrew two screws located at the speaker.
  11. HP Pavilion dv7t-7000 Speaker Replacement: step 11, image 1 of 1
    • Then take off the speaker and replace with the new one.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 23
All Time: 1,303
