Introduction
This guide provides instructions for replacing the motherboard of the laptop. If your laptop is not starting correctly, replacing the motherboard may provide a solution to these issues.
Make sure the computer is unplugged and turned off.
Place the computer front side down with the battery compartment farthest away.
Slide the switch under the battery compartment to the left until the compartment opens. This may require some force.
Unscrew the six Phillips PM2.5×6.0 captive screws with a Phillips #00 screwdriver.
Pry the back casing up and away from the rest of the laptop with the plastic opening tool.
Remove the five Phillips PM2.5×7.0 screws with a Phillips #00 screwdriver.
Remove the 17 Phillips PM2.5×3.0 screws with a Phillips #00 screwdriver.
Remove the grey mounting bracket by unscrewing the two Phillips PM2.5×3.0 screws with a Phillips #00 screwdriver.
Slide the bracket to the left to remove.
Turn the laptop over and open it so that the keyboard is exposed.
Lift off the speaker cover.
Remove the three Phillips PM2.5×3.0 screws, located on the speaker, with a Phillips #00 screwdriver.
Remove the four Phillips PM2.0×4.0 screws with a Phillips #00 screwdriver.
Begin to lift the keyboard off of the laptop.
Disconnect the black zero insertion force connector in order to completely remove the keyboard.
Unhook the black WLAN antenna cables from the clasps holding it in place.
Pull up to fully disconnect the ends of the WLAN antenna cables.
Unscrew the seven Phillips PM2.0×4.0 screws from the base of the screen with a Phillips #00 screwdriver.
Lift up the screen to remove it from the rest of the laptop.
Press in on the silver cover in order to eject the dust cover.
Pull the plastic dust cover to completely remove it from the laptop.
Unscrew the metal casing by first unscrewing the six PM2.5X5.0 screws with a Phillips #00 screwdriver.
Next, unscrew the six PM2.5X2.0 screws with a Phillips #00 screwdriver.
Rotate the motherboard so that the backside is now facing upward. It should still be connected by a single cable.
Unplug the white power connector cable. The motherboard is now fully removed.
