HP Pavilion dv2913cl Keyboard Replacement
    1. HP Pavilion dv2913cl Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Locate battery on the bottom of the laptop.
      Ask FixBot
    2. HP Pavilion dv2913cl Keyboard Replacement: step 2, image 1 of 1
      • Slide the battery release bar to the left, this should release the battery so you can then remove it.
      Ask FixBot
    3. HP Pavilion dv2913cl Keyboard Replacement: step 3, image 1 of 2 HP Pavilion dv2913cl Keyboard Replacement: step 3, image 2 of 2
      • Locate the three screws for the keyboard by finding the small keyboard picture, remove these screws and flip the laptop back over.
      Ask FixBot
    4. HP Pavilion dv2913cl Keyboard Replacement: step 4, image 1 of 1
      • Open the laptop so the keyboard is facing upwards and towards you.
      Ask FixBot
    5. HP Pavilion dv2913cl Keyboard Replacement: step 5, image 1 of 2 HP Pavilion dv2913cl Keyboard Replacement: step 5, image 2 of 2
      • Use the plastic opening tool to get underneath the plastic bar above the keyboard, pry upwards. Pry the keyboard upwards gently.
      • Be careful not to pull the keyboard too hard so you do not rip the silver ribbon cable attached to the laptop.
      Ask FixBot
    6. HP Pavilion dv2913cl Keyboard Replacement: step 6, image 1 of 2 HP Pavilion dv2913cl Keyboard Replacement: step 6, image 2 of 2
      • Release the ribbon cable by using a flathead screw driver. Release the two tabs holding the cable and pull outwards.
      • Pull the keyboard up and out from the laptop.
      Ask FixBot
Adam Braga
230 Reputation
2 Guides authored
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G7
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 20
All Time: 327
