HP Pavilion Wave 600-a014 RAM Replacement
  1. HP Pavilion Wave 600-a014 RAM Replacement, RAM: step 1, image 1 of 1
    • Disconnect PC from power source and any other devices.
  2. HP Pavilion Wave 600-a014 RAM Replacement: step 2, image 1 of 2 HP Pavilion Wave 600-a014 RAM Replacement: step 2, image 2 of 2
    • Turn over computer and remove the rubber feet.
    • Remove the three 8mm Philips screws with a Philips #0 screwdriver.
    • Use a pry tool and lift up on the lid.
  3. HP Pavilion Wave 600-a014 RAM Replacement: step 3, image 1 of 2 HP Pavilion Wave 600-a014 RAM Replacement: step 3, image 2 of 2
    • Remove the two cables connecting the motherboard to the front I/O panel.
  4. HP Pavilion Wave 600-a014 RAM Replacement: step 4, image 1 of 2 HP Pavilion Wave 600-a014 RAM Replacement: step 4, image 2 of 2
    • From the back I/O panel, pry open the cloth covering.
  5. HP Pavilion Wave 600-a014 RAM Replacement: step 5, image 1 of 1
    • Remove the 2 black philips screws on the outside of the PC, to the left of the fan.
    • There is one on the top and one on the bottom.
  6. HP Pavilion Wave 600-a014 RAM Replacement: step 6, image 1 of 3 HP Pavilion Wave 600-a014 RAM Replacement: step 6, image 2 of 3 HP Pavilion Wave 600-a014 RAM Replacement: step 6, image 3 of 3
    • Put your thumb on the penny-sized hole, and slide the panel upwards.
    • Remove the panel to reveal the stock blue RAM.
  7. HP Pavilion Wave 600-a014 RAM Replacement: step 7, image 1 of 3 HP Pavilion Wave 600-a014 RAM Replacement: step 7, image 2 of 3 HP Pavilion Wave 600-a014 RAM Replacement: step 7, image 3 of 3
    • Push both of the white tabs away from the RAM stick to free the RAM.
  8. HP Pavilion Wave 600-a014 RAM Replacement: step 8, image 1 of 1
    • You can now easily pull the RAM out of the socket, and replace up to two new ones!
2 other people completed this guide.
Arthur Knatt
149 Reputation
1 Guide authored
Cal Poly, Team S8-G4, Banghart Fall 2017 Member of Cal Poly, Team S8-G4, Banghart Fall 2017
CPSU-BANGHART-F17S8G4
4 Members
5 Guides authored
One Comment
Hello srs, i follow the link to the Amazon Ram, and it is So-DIMM, but we need UDIMM for this Wave, it is correct? Wich can we use? Thank you so much, and best regards.
Albert Garcia - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 26
All Time: 2,947
