HP Pavilion Sleekbook 15-b000 Keyboard Replacement
  1. HP Pavilion Sleekbook 15-b000 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: step 2, image 1 of 1
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: step 3, image 1 of 2 HP Pavilion Sleekbook 15-b000 Keyboard Replacement: step 3, image 2 of 2
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: step 4, image 1 of 1
    • Pull battery out.
  5. HP Pavilion Sleekbook 15-b000 Keyboard Replacement, Keyboard: step 5, image 1 of 1
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: step 6, image 1 of 1
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: step 7, image 1 of 1
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: step 8, image 1 of 1
    • Remove keyboard wire by popping latch under blue plastic
Sam Barkley
1,007 Reputation
8 Guides authored
USF Tampa, Team S11-G2, Cheng Spring 2018 Member of USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 22
All Time: 514
