HP Pavilion Notebook 15-ab293cl Hard Drive Replacement
  1. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Flip the laptop over so that the battery is facing upward.
  2. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 2, image 1 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 2, image 2 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 2, image 3 of 3
    • Slide both tab buttons inward to open the battery cover. Gently push the battery out to remove.
  3. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 3, image 1 of 2 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 3, image 2 of 2
    • Remove the black plastic hinge covers at the top corners of the laptop.
    • Use the Phillips #1 to remove the two 7.5mm screws.
    • Use the opening tool to pry the black covers off of the laptop.
  4. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 4, image 1 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 4, image 2 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 4, image 3 of 3
    • Remember to remove the tabs shown in the second picture.
    • Remove all 16 - 7.5mm screws with the Phillips #1 screwdriver.
    • Pry and slide the CD/DVD drive out of the laptop case.
  5. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 5, image 1 of 1
    • Unscrew the two 3.5mm silver screws with the Phillips #000 and the Philips # 1.
  6. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 6, image 1 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 6, image 2 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 6, image 3 of 3
    • Turn the computer so that the screen faces you.
    • Use the pry tool to pry off the edge of the keyboard side of laptop.
  7. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 7, image 1 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 7, image 2 of 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 7, image 3 of 3
    • The hard drive is located in the bottom corner of the laptop.
    • Gently lift up the hard drive and pry off the white tab to release the hard drive.
  8. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 8, image 1 of 2 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: step 8, image 2 of 2
    • Once you release the white tab from the green board, remove the hard drive.
Efren Solis
228 Reputation
1 Guide authored
Gateway, Team S1-G2, Luster Fall 2018 Member of Gateway, Team S1-G2, Luster Fall 2018
GCC-LUSTER-F18S1G2
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 48
All Time: 3,324
