HP Pavilion Notebook 15-ab293cl CPU Fan Replacement
  1. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement, CPU Fan: step 1, image 1 of 2 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement, CPU Fan: step 1, image 2 of 2
    • Start by flipping the laptop, revealing its back.
  2. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 2, image 1 of 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 2, image 2 of 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 2, image 3 of 3
    • Slide the tab marked with a lock/unlock symbol. The slide the other tab in order to release the battery.
  3. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 3, image 1 of 2 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 3, image 2 of 2
    • Once the battery is removed, unscrew and remove the both of the 7.5 mm screws off the black tabs using a PH1 screw driver. Then pry off the covers using the plastic opening tools.
  4. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 4, image 1 of 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 4, image 2 of 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 4, image 3 of 3
    • Remove all 16 size 3.5 mm screws with a PH1 screwdriver and pry the CD drive in order reveal one last screw that must be removed.
  5. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 5, image 1 of 1
    • Utilizing either a plastic or metal opening tool, begin prying the case from the laptop. Lastly, remove the remaining clips located on the back of the laptop.
  6. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 6, image 1 of 2 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 6, image 2 of 2
    • Once the laptop is fully open locate the cooling fan.
  7. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 7, image 1 of 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 7, image 2 of 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Utilizing a PH00 Screwdriver remove the two 3.5 mm screws detaining the cooling fan. Then use tweezers to remove the plug connecting the cooling fan to the mother board. Lastly remove the cooling fan.
5 other people completed this guide.
John Carlo Barajas
229 Reputation
1 Guide authored
Gateway, Team S1-G2, Luster Fall 2018 Member of Gateway, Team S1-G2, Luster Fall 2018
GCC-LUSTER-F18S1G2
4 Members
4 Guides authored
1 Guide Comment
very detailed. Thanks!
mrobinson29 - Reply
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 16
All Time: 1,426
