HP Pavilion N3350 Optical Drive Replacement
  1. HP Pavilion N3350 Optical Drive Replacement, Keyboard: step 1, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement, Keyboard: step 1, image 2 of 2
    • Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
    • To remove this, pry it open with a spudger tool gently. It should pop out of place.
  2. HP Pavilion N3350 Optical Drive Replacement: step 2, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement: step 2, image 2 of 2
    • Remove the three 6mm screws using a Phillips #1 screwdriver.
    • Once the screws are removed, the keyboard is free from the base of the laptop.
  3. HP Pavilion N3350 Optical Drive Replacement: step 3, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement: step 3, image 2 of 2
    • Disconnect the green ribbon cable using a plastic opening tool.
  4. HP Pavilion N3350 Optical Drive Replacement, Optical Drives: step 4, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement, Optical Drives: step 4, image 2 of 2
    • Remove the 6 millimeter screws indicated with a Phillips #1 screwdriver.
    • Remove the top plastic covering from the base of the device.
  5. HP Pavilion N3350 Optical Drive Replacement: step 5, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement: step 5, image 2 of 2
    • Use a plastic opening tool to disconnect both cable connectors gently.
  6. HP Pavilion N3350 Optical Drive Replacement: step 6, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement: step 6, image 2 of 2
    • Once these cables are disconnected, the optical drives can be found inside.
    • This particular laptop has a CD/DVD combo drive on the left, and a floppy disc drive on the right.
  7. HP Pavilion N3350 Optical Drive Replacement: step 7, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement: step 7, image 2 of 2
    • The 1 centimeter screws indicated need to be removed using a Phillips #1 screwdriver to free the CD/DVD combo drive.
    • Once freed, the CD/DVD combo drive should slide out and remove easily.
  8. HP Pavilion N3350 Optical Drive Replacement: step 8, image 1 of 2 HP Pavilion N3350 Optical Drive Replacement: step 8, image 2 of 2
    • The 1 centimeter screws indicated must be removed with a Phillips #1 screwdriver to free the floppy disc drive.
    • Remove the floppy disc drive from the device.
Lyndon Davis
124 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 354
